CYA of 100 is still too high, but much better than 140. Drain/refill dance, again.
You are using the CYA 50/50 dilution test, right?
AdrenalinPlease said:Nature2 canister has been removed also.
Don't worry about shocking until you get your cya down.AdrenalinPlease said:I will drain it some more this evening. I need to shock the pool tonight also. I'm not quite getting the pool calc so how much 12.5 liquid chlorine should I use?
My trick is to not stare at it too long or I will see the dot, my kids faces, and any other trick my mind wants to play on me.AdrenalinPlease said:Yeah, I still have trouble with it lol I can see the dot outline somewhat when I stop and then I feel my mind playing tricks on me.
