Sounds okay. You're looking for a color change, not an exact shade. You targeted 70, so you're in the ballpark.while testing the pH (7.0) and TA- something weird happened. I was adding the r0009 and at the 8th drop it turned all pink for a second then immediately went clear. I did the test again because I assumed I did something wrong and it happened again, at the 8th drop. Normal? Proceed as TA at 80ppm? I'm moving on to add the liquid chlorine now. Thanks for all the awesome help I've been given
