- Jun 24, 2021
- 16,069
- Vinyl
- CircuPool RJ-60 Plus
Rare. What are the symptoms?and my speedstir doesnt work. awesome
Check that batteries are in the proper direction.and my speedstir doesnt work. awesome
batteries installed and nothingRare. What are the symptoms?
ok Crud i just posted the other. let me get the info and then you can delete itPlease continue this thread.
Where should I start? I will wait for a reply before heading to the store to start tonight
should i just focus on each priority one at a time each day? or try to add it all in one dayJust Filled Your Pool with Water? Here's What To Do Next - Further Reading
www.troublefreepool.com
Add enough dry stabilizer to get to 30ppm. Get at least 7 pounds.
Are you going to clorinate with Liquid, get liquid chlorine
You will need muratic acid at some point, just not right now. Might get it to have it on hand.
Great place to start:
I do not have any soda ash though
Make sure you know what strength it is and adjust the poolmath accordingly so you won't over or under apply it and wonder what happened in your outcome.2 gallons of muratic acid
Whatever you do don’t store the chlorine and the MA near each other - they react potentially lethally
Many store the MA outside - by itself it vents from the bottle and fumes are very corrosive to metal
oh really I didnt know that. Is it good to store them outside where sunlight will hit either in the morning or in the evening
