Is there a test kit available for color deficiency people?
Alex, I'm going to offer my own personal opinion so you have something to go on. I've been blind in my right eye for 30 years this July. Last year my left eye started mimicking the same issues my right eye did, but unlike 30 years ago, we now have eye injections. Yes - a needle in my eye each month. Why am I sharing this since it's not quite the same as being color blind? Well, with my left eye struggling, my color definitions are changing. I'm not totally color blind, but it's not the same as last year and it's getting worse. So for most drop tests, we emphasize that in most reagent cases, it's the shade changing that is most important. Your signature is empty so I don't know what kind of pool you have, but if it's vinyl the CH should hopefully not be an issue unless you have exceptionally hard water or use a ton of cal-hypo. Your TA, FC, CYA, and pH will be most critical. The CYA is focused on the dot, so that shouldn't be an issue. The TA and FC should reveal shade changes when mixing. It's the pH that could prove most challenging. So my recommendation would be having a friend or family member read the pH with you, or try one of the digital meters. There are various ones out there, so there is no one perfect meter. While we don't recommend the pool store, the pH is (or should) be very simple, so you could go there in a pinch, just ignore everything else they say.
As for the test kits in general, you'll always find that we (TFP) recommend the TF-100 or Taylor K-2006C equally because of their proven reliability for residential home testing, availability, and reasonable cost. Both provide the necessary "shade" changes someone who is colorblind should recognize. Of course owners are welcome to invest and try the multitude of other kits out there, but we hesitate to offer TFP advice on those other kits (here) because of questionable reliability with some of the tests.
We have several other threads about this discussion. I think the optimal way forward is to practice the FC, TA and CH (if needed) with someone to recognize the color changes. The pH is the odd-ball and I mentioned that one above. Vision is something most people take for granted everyday, so I understand at this point in my life how sensitive the issue is. I'll leave by saying that vision challenges can be met with more than one option and we're happy to discuss those options with all our members. If at some point you find an alternative way to test, please share them with us since we have many members in the same situation. Take care.
