Hi,
Knowing about the importance of testing my own water, the research done so far on getting TFTTestKits or
Taylor Service Complete Pool Water Test Kit K-2006C does not ship to South Africa.
I'm left with one or two local brands of water test kits including the HTH 4-in-1 Test Kit that can do FC, Ph, Total Alkalinity and Acid Demand.
The local pool shop can test results correspond with my own home test results on Ph, FC, Total Alkalinity. The pool shop uses a test strip scanning machine for industrial use.
The pool shop can test CH, TC, FC, CYA.
How will I be able to test during SLAM? Friends and family who are also pool owners use the same test kit(HTH) and adjust to maintain FC level between 1 and 3, PH between 7.2-7.6 and Alkalinity at about 100ppm.
Is there anyone that can suggest a supplier that would ship to South Africa that can provide the FAS-DPD test? I'll need to rely on my current test kit with the results from the pool shop for now.
