Rattus Suffocatus
- Jun 5, 2019
- 1,657
- Plaster
- CircuPool Universal40
Okay.. well I probably should add borates, but we for some crazy reason have four dogs now (long story) who all think the pool is their personal water bowls. They apparently must like the little bit of salt that's in there for the SWCG. (They are like children, you are outnumbered at #3). I am continuously pulling gravel out of the bottom of the pool and one of the other projects is coming up with something just to pull rocks out... PVC with a plunger and a check valve or something for the rocks. The little $15 WalMart Venturi vacuum on a hose works well, but it's a pain to lug the hose out almost daily....Mr. Suffocatus, I learned those test strips, first of all, are not near as accurate as titration (drops). In fact, once I've used up my Taylor T100 kit, I'm going back to Ace Hardware-type 5-1 test kit (Chlorine/bromine, TA, pH, acid demand...read cheap here). It was nice pretending to be a hydrologist with the T100, but I pretty much know my pool now here at Houghton/22d. I'll use the 7-1 test strips to back up the drops, I guess, and check CYA. So, verifying TA with the drops is first thing for me, then pH and chlorine. I lower TA to 80ppm using only the 31.5% MA, no more that one pint each dose until 80 hit. Truthfully, if I overdo it with the MA and it goes lower, I don't care as pH always climbs here, y'know. I converted my pool to borate to stabilize pH, but before that had no TA problem using MA. Just make sure the other ranges are in check, like for TDS and CYA, sneaky trolls fer shore, Pard...JS
As for Borates, I am aware that if I put the TFP recommended levels in the dogs would probably be okay, but if I can manage it otherwise I would rather avoid the risk. If I poisoned one of the dogs, it probably would be divorce time here... I might try maybe a third of the recommended levels next year and see if it makes any difference. I'll try to train the dogs not to drink out of the pool but.. good luck....
At Houghton and 22nd (I'm roughly at Houghton and Sahurita) you are on the main system which is actually slightly worse overall than the CDT system if I am to trust the reports from Tucson Water. So you are doing well.
I actually use that Ace kit (I buy refills from Ace but when I need a new plastic vial I buy the kit from Home Depot... it's the same kit)... It's just as good for pH and better for TA (purple/clear is much more readable than Red/Green is!) in my opinion than the Taylor/TF kits are. The OTO test in it is interchangeable with the Taylor... Accuracy is exactly the same. Much cheaper so I can test basic levels more without dipping into the TF-100 all the time. But yeah strips are way too vague.
I have the problem of pH not rising enough when I do MA additions here. I think I need to get better aeration (or do borates) so I am going to work on something to aerate the pool when I am off over Christmas. It probably will have to use my external utility pump but that would be okay honestly.
But even at keeping the TA at 100, my pool has *far* less tile line calcification than... well.. anyone else's pool (all but one on "Services") in the neighborhood. I am still scaling the SWCG up more than I would like so that is why I am asking. I suppose I will figure it all out next year. I am amazed that the cold snap we had here literally has made the water temperature go down 11 degrees F in three days... I don't have heat.... season's over with anyway... I am curious how much lower in water temp the SWCG will run.. it's still fine at 64F though... But I might start on that project sooner than I think...
