I just installed a Stenner pump. I used a 2" to 1/2" T fitting to put the injection nozzle into the main pool line.
It has a very small leak, like a couple of drips every few min. I was wondering if I could wrap a little teflon tape around the injector or would that be a no-no?
This is not a leak with the injector. I had a plug in the 1/2" hole prior to installing the injector and that had a very small leak also. And when i say leak, you would only feel it if you put your hand on it and it would be slightly wet.
Thanks
Thanks
