I use unstablized liquid chlorine which is added using the HASA liquidator feeder dispenser. A lot of the salt in the chlorine falls out of solution in the tank and never reaches the pool so that keeps that TDS down but I use dry acid because of health concerns to adjust my PH and I just learned this adds a sulfate (TDS) to the pool over time and can combine with Calcium (which is in tap water) and become a big problem so it's important to control that. So I'm trying to find the best remedy without switching to Muriatic Acid. I guess I could put in a softener that removes the calcium in the water I use for the pool but that increases the salt level too. Is there a way to test for sulfates and what would the limit be? I should add I only us liquid chlorine to shock when needed to avoid adding calcium in large amounts and I add a descaler treatment once a month too which does keep my tiles clean along with equipment. Or would just doing a partial drain each year be the best over all solution?
