Taylor Test Station
To simulate daylight with clear sky (sun overhead) you want a white light in the 5000-6500 K range
Yeah, see, that's what they say, and the color range of the supposed 'daylight' bulbs is anything but. They are obnoxiously bright, but in a LED flashlight way and not the backyard patio table at lunch kinda way.
The meat department uses those same bulbs but in actaul daylight, the meat looks entirely different.
Reactions: afbatts
Adjustable Brightness: Adjust LED light panel brightness from 1% to 100% for enhanced control.
Works great as an LED light for photography, or as camera lighting for video recording for YouTube.
Adjustable Color Temperature: Flicker free LED panel light with adjustable color temp from 3200K to 5600K.
I need a good light source for my TikTok dance videos, this one should be a good choice.
Daylight is free. I walk outside, if testing inside, or get off my rear and walk onto the pool deck to compare colors on the pH comparator. I normally do the CH test on the patio so I can see the distinct color change to blue. If testing in the house, I place the 3 x 5 card that came with the K-2006c behind the speedstir to see the other colors.
If I just had to spend a $1,000 on something, hmmmm...
Reactions: afbatts and Newdude
