I bought some stabilizer today at Walmart and picked up a packet of the HTH test strips simply because they include a CYA test. My stabilizer is close to zero. By the way, my initial impression of these HTH test strips is that they are quite accurate and amazingly convenient. They matched all of my most recent readings from the K2006. I agree that the K2006 Test Kit is hands-down the best for testing FC, TA, PH, and CH. What I like about the these liquid reagent and titrant tests is that there is no guesswork involved. You put drops in the free chlorine and count them until it turns completely colorless. All of them pretty much work the same way except for the CYA. Without question, this is the worst test of an otherwise superior testing kit. I've argued with a few diehard K2006 fans about this before, so I know many of you won't agree, but the CYA test is really difficult for my eyes. When I begin adding the cloudy solution to the tube, the sun, shadows, reflections all play tricks on my eyes. After a while it is difficult for me to tell if I am seeing a black dot or just a shadow. Or, is that a hint of black I am seeing or just my imagination? So, today I tried one of the convenient HTH 6-way test strips. In 60 seconds the HTH test strip confirmed what I suspected: My CYA level is close to zero. I had to waste 14 ml of the R-0013 before I came convinced of this before. I wondered if I did something wrong because the solution didn't become the least bit cloudy. At any rate, I like having the strips for quickness and convenience. You can compare, then calibrate your results with the K2006 to gain confidence in using them frequently. I will re-check my stabilizer in a couple of days with both the K-2006 and HTH strips and share what I find.
