taylor 2006 TA test
danbergstrom
11
Aliso Viejo/CA
doing the TA test counting drops to red....which red....
first there is not green but not red. i can pretty much rule this one out.
next drop
then there is red.
next drop
then there is red you don't want to look at because it is so bright you are worried you might somehow ruin your eyesight.
thanks
proavia
1,969
Chandler AZ
I have heard it termed "barbie pink".
No matter, you continue to add drops until the color no longer changes - and subtract the last drop where the color doesn't change.
drsipe
36
Middletown, Pennsylvania
You add drops until the color does not change, so if 6 drops turns it red, and drop 7 turns it brighter red (kind of barbie pink) then you add drop 8 and the color does not change, you only count the number of drops that caused a color change, so 7 drops, equates to a TA of 70.
Reactions: Mdragger88
