I was able to get a Intex SWG fairly cheap and am taking the plunge. Waiting on my test kit to get here so I can see how much salt I have present in my pool prior to added the recommended amount to get to 3000ppm. My questions to the pool experts are...
1) Is salt, salt?? Meaning can I use salt for water softeners or do I need pool salt? I plan on dissolving it in a 5 gallon bucket prior to putting it in the pool so I don't do any damage to the liner.
2) I leave my filter pump running 24/7 just because... I understand that I need to check my FC at the same time to determine how much chlorine I lose so that I can adjust the SGW to produce that amount daily. Does it matter if my filter runs 24/7 or not (minus power consumption and wear and tear on my pump)?
3. My CYA is at 50. Do I need to raise it to 80ish prior to checking the FC drop? (sounds like a stupid question, because the higher the CYA the less FC I will lose)(I think I answered my own question.. LOL)..
Thanks in advance!!
Cheers!!
Thanks in advance!!
Cheers!!
