I browsed a few other threads but my situation seems unique:
Pentair Legend cleaner- the 3-year old original tail and new tail stopped sweeping. I recently replaced the backup valve. I tore apart the internals, cleaned out all the hoses, inlet screen is clear, booster pump works and puts out good pressure/water volume.
When I run the cleaner and take the weight off the wheels (dangle it in the water), the tail starts slowly sweeping. Once the wheels touch back down it stops.
Could this be a wheel bearing issue? Or more likely the backup valve fighting for water?
Thank you for your suggestions!
