I'm trying to get my water better balanced this year then the last and my TA and CH were off. I've been guilty the last 2 ears of focusing on PH, CYA, and CL and letting the rest slide, luckily without too much problems.
My readings yesterday were:
TA=130
CH=80
CL = 8 (I have been adding bleach to SLAM, then plan to raise the CYA and have a Salt Water/CL Generator Pool)
PH=7.2
CYA=0
I wanted to lower the Total Alkalinity to 100, so using the chart in the DPD test kit, I should add 1.5 gal of muratic acid to drop the TA 30 ppm in my 25,000 gal pool..
This morning when I checked, my TA was now 170! It went UP 30 not down 30! I thought I must have misread the chart so I double checked and It does say Muratic Acid to DECREASE.
What the heck happened? Am I going at this correctly? I am getting my PH between 7.2 and 7.6 the working on TA, CH, CYA in that order while doing whatever is needed to keep PH in the 7.2-7.6 range.
Thanks for any insight or help!
Dean
TA=130
CH=80
PH=7.2
CYA=0
Dean
