Hi all,
I have been working for a year to get my water levels under control following a drain-refill thanks to the previous owners puck habits. Our fill water has extremely high CA and TA levels. Thanks to refilling with softened water the CA level is now acceptable (500). However, I continue to struggle with TA. Last year I could bring it down to about 120, but then refilling would bring the level up again. Acid-aerate-repeat all summer had no net improvement once I got to the 120-150 range, since the 500 TA fill water kept is rising.
One reason the aeration cycle was not that effective was because the pH took a week to rise from 7.2 to 7.6. In hindsight, was this telling me that my pool was very happy with a TA in the 130 range? Reading over the past few weeks many experts say to not worry about a number, but look for pH stability. My pool seems stable in the 120-150 range.
That being the case, if I add borates is my TA going to go through the roof since I won't be adding 1-2 gallons of acid each week?
