linen said:Well water often times has high calcium hardness (mine is in the 300s) so if you have added it to your pool off you may raise your CH level...but as you noted 1/8inch would not be much (but over a few weeks time it can add up). Did you fill the pool with the well originally?
The Cal-hypo added a little and the test accuracy is +/-10%.
No, I did not fill any well water into pool, just let rain and snow accumulate over the winter and melt into the pool. with Gunite pool I only drain it enough to close the plugs. How soon after adding Calcium can I test CH? and finally, if I finished adding calcium and since I was shocking last night, can I shut down the pumps and the filter untill I get back home tomorrow after work? Since the water is already clean and SWG is off is there a point to run it?
