Higher ta only makes the ph rise faster it doesn’t really harm anything else.
Aeration increases ph without increasing ta so you can then lower them both with acid.
You can do this aggressively by actively aerating so ph rises faster so you can then lower it (no lower than the 7’s)
or just not worry about it & lower ph whenever it rises to 8.
Once ta gets below 100 each acid dose has a more noticeable effect on ta in my experience.
Once ta gets around 60 or so most people have noticeable slow in the frequency of ph rise.
What is your fill water TA? That has a large effect depending upon how often you need to top the pool off.
In fact it’s good to know your fill water’s
Ph
Ta
& ch so you know how that affects your pool chemistry.
I see you’re using cal hypo on a regular basis - this increases your ch. Too much ch increases the potential for scaling of surfaces & in your salt cell. You want your csi to be neutral to slightly negative.
While a lower ta helps with this there are multiple contributing factors including ch.
you can fiddle with csi in poolmath to see what each change will do.
I suggest using liquid chlorine whenever you need a bump in fc then set your swg to maintain your target
FC/CYA Levels
Your fc has gotten quite low for your cya in the recent youpast.
You may need to do an
Overnight Chlorine Loss Test to rule out something brewing that is consuming your fc.
Have you had alot of rain/ overflow/replaced a bit of water in the last couple weeks?
Your cya & salt have gone down but your ch has increased.
