I am going to switch to salt since I am replacing my liner and my cya is through the roof from the chlorine pucks. I am pretty certain I am going with the Circupool RJ 60 plus. I am currently running a single speed pump. I run my pump 12 hours a day, 7 am to 7 pm. It is on a digital timer. My heater is on direct power, not wired into my pump or timer. I will install this system myself but I have a few questions.
Will I need to replace my pump with a variable speed? After the cost of the liner and SWG I really need to slow down the outflow of money!
Can I just plug the unit into my 110v power receptacle or do I need to wire it into my timer box? From what I have read there is a flow meter so if the pump is not running the SWG will not run either. That being the case I really see no reason to mess with wiring into the timer box.
