I just drained and refilled my tub after an Ahhsome purge (other thread). I’m going to switch to the bromine method here (from the sticky). I have a few questions for my start up.
I have high iron from my well and fill by going through a whole house iron filter, water softener, special iron hose filter and then into the tub. I then put in MetalGon and the bottle says to run for 24 hours before anything else is added. Here are my questions on next steps after waiting 24 hours.
Do I check CH first as it should be low. And then add Calcium Hardness?
After that do I adjust TA and then pH? And from there follow the bromine startup sticky?
