- May 27, 2022
- 15
- Plaster
- Pentair Intellichlor IC-40
The equipment set installer setup our intelllicenter panel with pool and spa mode which I think is pretty typical. The spa spillover is at water height. We have shared equipment and two intellivalvws which regulate intake and return to pool and spa. We also have a dedicated pump for spa jets.
Question after using the spa for the first time on the weekend.
To heat the spa, of course I set the intellicenter to spa mode and added heat. After 15 minutes she was warm and heater kicked off. Pump continues to circulate in spa and no spillover is happening.
Let’s say kids all moved out of the spa and into the pool and I wanted to turn on pool mode to keep filtering running in pool… I would then select pool mode. However, this basically vacates the spas heated water as pool mode returns water to both spa and pool.
Is it normal to switch modes back and forth during a swim day, and can you setup a specific circuit which leaves the spa water uncirculated while you are in a “pool only” mode?
Separately I don’t understand how you configure the intellivalve circuits. Do you just select the circuit in the intellicenter app, then set the valve?
