We sure needed the rain the other week, but once it started it never stopped. Fall weather came early. I was hoping for just the opposite being that we had no early fall trips planned this year. Time to close up...
Exactly. If the climate continues a warming trend - probably little to worry about with freezing pool (underground) plumbing. Open earlier and close later!For me the pipes drop 4 feet at the pool and the equipment pad and everything in between would take an insane winter to matter
I was just thinking the exact same thing. My Sears 1 HP compressor had less power than the Porter Cable pancake that replaced it. There is way more pressure coming out of those return lines than would have to be even though I have the gauge turned all the way off.You mentioned that you use a compressor for blowing the pipes. Perhaps the pressure is too high?
No...I've never removed the springs from the straps. All that hardware simply gets folded in as I pull the cover off a few feet at a time.Do you detach springs from the straps before opening the pool?
I would think so as well, but what other explanation could there be? A plug has never fallen out before (once I'm done blowing out the lines). Makes no sense, but has me paranoid. Will a plug fall out at some point during the winter? Not about to keep taking off straps every few days just so I can stick my head under the cover and check! I did that after adding the antifreeze and they were still in there, then checked again a few hours later. Maybe at this point better not to know and just let it go till spring. It just seems odd that every time I use a plug I've bought in the last few years, I have some sort of problem, and as soon as I wind up using older plugs, it works. I noticed that the older plug even goes in the pipe farther. And so wondering if - with the newer (stiffer?) plugs, the more I tighten, perhaps the more it starts to push out rather than simply get tighter against the pipe.and it's not likely that during closing you would pull out return plugs with the straps alone.
