I've read most of the posts regarding SWG and stenner chlorine pumps, but have a few questions before I pull the trigger. Right now, I'm adding liquid chlorine, but would like to make the process more automated. I'm leaning towards a SWG but I'm concerned about corrosion to my autocover. It's been addressed before and some say that the risk is exaggerated, but most people were hesitant to say definitively.
1.) Has anyone had experience with corrosion to autocover parts while using salt water pool? Or conversely, have people used an autocover for years with salt water without problems?
2.) I read the warranty on my autocover, it doesn't seem to limit coverage due to corrosion from salt water. Has anyone had trouble getting repairs covered?
3.) I've read that a zinc anode can limit the damage, but my PB says that an anode was not put in at time of construction. Is it difficult to install an anode after the fact? The cover motor seems to have a ground wire attached to it, but I have no idea where it goes.
Regarding stenner pump:
4.) Can the chlorine sit outside without degrading if the container is opaque? I've always kept my chlorine sheltered from the sun and heat.
