- May 23, 2015
- 25,733
- Plaster
- Pentair Intellichlor IC-60
All of this input is great, thanks. Back to one of my original questions: 1 jug of bleach = how many pounds of chlorine? Most of the specs on the generators have pounds/day and I wanted to know how many jugs that would be in comparison.
The calculation is not hard to do, but it rests on some assumption. If you want to know the weight percentage of available chlorine in a bottle of bleach, then you take the weight percent of sodium hypochlorite and multiply that by the ratio of the molar masses of chlorine gas (Cl2) to sodium hypochlorite (NaOCl), or
Weight % Available Chlorine = Weight % NaOCl * (Cl2 g/mole) / (NaOCl g/mole)
Where,
NaOCl g/mole = 74.442
Cl2 g/mole = 70.906
For example, a 121oz bottle of 8.25% Clorox has,
8.25% * (70.906 / 74.442) = 7.86 wt% available Cl2
One minor issue when trying to calculate the actual weight of Cl2 is that the specific gravity of bleach (density or lbs/gal) can vary depending on the manufacturer. Bleach has excess lye in it to raise its pH above 11 so that the hypochlorite remains stable in solution. So solution weights will vary a little.
As others have mentioned, and as I posted in my first response, it's just easier to calculate the FC using PoolMath and compare. In your pool volume, 1 gal of 8.25% bleach adds 3.3ppm FC. The IC-40 running at 100% and 24 hours adds 6.9ppm FC. So running the IC-40 for 12 hours per day will be a close approximation of 1 gal of 8.25% bleach. This is why I suggested you might be better if with an IC-60.
Best wishes,
Matt
Sent from my iPhone using Tapatalk,16k gal SWG pool (All Pentair), QuadDE100 Filter, Taylor K-2006
