I am done with my build thankfully after almost 3 years. The only pool contractor that would travel to my location and build it would not install a salt water system. We have been using pucks even though I have been on here for a while and know of the high cya levels, it is the only way he would warranty any of the equipment. So now that I have a year under my belt and I’m sure the warranty is up, I’m curious if I should install a ic40 or an ic60. My pool is 28000 gallons and from reading multiple posts, I know you want to double the size, but since I’m a little bit below double for a 60 I didn’t know if it would work properly as I run my VSP 24/7. Let me know which direction I need to go. Thanks!
