- Jun 2, 2022
- 104
- Plaster
- Pentair Intellichlor IC-40
Good afternoon,
I’m starting to plan for my SWG installation. I’m planning a Pentair IC20 (10000 gallon pool/spa) with the transformer and surge board inside my load center. I’m looking at a Jandy spring check valve between the heater and the IC20. Below is a picture of the return line going to the return valve. The lines are 2in PVC. The pool equipment is higher than the pool.
I’m trying to figure out the best way to plumb this system in. I’m considering:
1). IC20 horizontally on line 1, check valve vertically on line 2.
2). IC20 horizontally on line 1, 90 degree check valve at junction of line 1 and 2
3). IC20 and check valve vertically on line 2. Use 2 90 degree PVC fittings to step line 1 back down to return valve level. (Maybe 2 45 degree fittings if I can make it fit). There is plenty of slack in the blower power line if I need to raise it.
I would appreciate any advice on the overall plan and plumbing. I’m open to any and all ideas.
Thanks!
Scott
Thanks!
Scott
