SWG Plumbing placement
jsygrls
283
Port Orange, Florida
So I've been kicking around the idea of SWG CircuPool RJ-60 PLUS , DIY, and need some hand holding on its ideal placement. Please take a look at some photo's.
Am i making more out of this than necessary?
1. Remove the in (not in use) inline chlorinator, create a loop and add the SWG and flow switch?
2. Create a loop from the filter out going to the heater.
3. Create a loop on the heater return?
20240329_095539.jpg20240329_115253.jpg20240329_095550.jpg20240329_115322.jpg20240329_121500.jpg
The only thing you'll be kicking is yourself. For waiting so long. Trust me. 😁
The SWG is the last piece of the pad puzzle. It needs to be after the heater. The flow switch can go anywhere that only gets flow when the SWG does, so it doesn't think the unit has flow when its been diverted around it somehow.
If going vertical, the flow switch goes on the up pipe so gravity doesn't close it when it fails one day. The RJ-60 can go on either.
The tab feeder looks like a good spot but if you like any other options that fit the rules, you're the one cutting and glueing so have at it.
Reactions: jsygrls
Cut out the tablet chlorinator and install the RJ cell vertical. The spacing of the pipes should give you a nice vertical loop for the cell.
Reactions: jsygrls
