I modified one of the frequently posted diagrams to add a AquaRite T-15 SWG unit/cell and flow meter. I added a anode into the diagram, but I'm debating whether to skip this. My pool setup feeds a 12k gallon San Juan pool and a San Juan hot tub. Only one pump. Along with installing the SWG, I am upgrading to Intelliflo VS pump, PE635RC controller, valve actuators to automate switching between pool and spa. The existing Jandy Lite2 heater and the 250 lbs sand filter, 62 gpm flow rate is being used. Any thoughts on this setup? The existing plumbing is four two-way valves for returns/drains. The pool only has a single main drain (plus skimmer). Will add a main drain safety cover over the pools main drain.
I should probably label this diagram with minimum recommended distances between various connections as that would be useful when plumbing this in. How useful is the spa make-up (allowing slight amount of water to go to spa) if the spa drain is not open? Is it just better to switch to the hot tub for an hour a day to circulate? I would love to figure out a way to circulate the spa water to the pool water, so everything is mixed and chlorinated the same.
