SWG is not turning on during automation run, but is when in service mode or manual.
I have my main pump programmed to automatically run for about 8+ hours per day. The past couple of days towards the end of the cycle I’ll notice the remote control panel in the house shows pump as “Off”, pump is/was running, and the SWG control panel back behind the pool with the rest of the equipment has no lights and the diagnostics window is blank -> Off. Can look tonight and see what the remote control shows when it starts up..
If I turn the system to Service mode and start the filter, or manually turn the pump on from the remote control panel in the house the Salt Generator control panel lights up and seems to function as expected.
Has anybody seen this before?
I just finished up a SLAM on it too Link below to that thread.. Seemed to be working fine before and shortly after..
https://www.troublefreepool.com/threads/130167-SWG-help
thank you
thank you
