I live in North Jersey and the pool has been sparkling all year long but we've hit a span of 8-12 days of 85-95F with little rain so I have been supplementing hose water every 4-5 days to maintain water level. I typically maintain a good FC/CYA level but last few weeks I've been adding a bit of liquid chlorine as the pool has had heavy use and the sun has been heavy. Last year, I kept the SWG at 80-85% but I've been at 90-98% this year but it's been hotter. Or, am I compensating for a failing SWG?
A day or so ago, I noticed a tad bit of green in one corner of the pool a few days ago which I brushed. Today, around 6PM I've noticed quite a bit of surface green algae on sides and corners which I brushed and added 3G of 10% liquid chlorine and I am leaving the pump on all night. It's been hot and the pool has been heavy used from Sat-Monday for 6 hours each day with multiple adults and kids (PEE!). The water still looks good but the algae is concerning as I dropped FC overnight and the FC isn't holding with the SWG nearly all the way at 100%.
Please see timeline below:
July 11th @ 4PM
TA 70PM
SALT 3400PM
TEMP 81F
PH 7.6
FC 3.5
CYA 60PPM
NOTES: Don't remember if any chlorine was added
July 16th @ 4:24PM
TA 70PM
SALT 3200PM
TEMP 82F
PH 7.6
FC 5.5
July 16th @ 9:53AM
TA 70PM
SALT 3200PM
TEMP 79F
PH 7.5
FC 4.0
July 19th @ 12:50PM
FC 6.5PM
July 20 @ 5:31PM
FC 4PPM
SALT 3200PM
CYA 50PM
TEMP 85F
NOTE: Added 1GAL of 10% liquid chlorine and cya
July 21 @ 5PM
FC 5.5PPM
July 22@ 9:52AM
FC 4.0
SALT 3100PPM
CYA 75PPM
TA 60PM
PH 7.4
TEMP: 84F
NOTE: Added 3GAL of 10% liquid chlorine and noticed surface green algae and FC dropping from 5.5PPM to 4.0PM from previous 5PM reading
July 11th @ 4PM
TA 70PM
SALT 3400PM
TEMP 81F
PH 7.6
FC 3.5
CYA 60PPM
July 16th @ 4:24PM
TA 70PM
SALT 3200PM
TEMP 82F
PH 7.6
FC 5.5
July 16th @ 9:53AM
TA 70PM
SALT 3200PM
TEMP 79F
PH 7.5
FC 4.0
July 19th @ 12:50PM
FC 6.5PM
July 20 @ 5:31PM
FC 4PPM
SALT 3200PM
CYA 50PM
TEMP 85F
July 21 @ 5PM
FC 5.5PPM
July 22@ 9:52AM
FC 4.0
SALT 3100PPM
CYA 75PPM
TA 60PM
PH 7.4
TEMP: 84F
