I got my test kit yesterday! Here's what I've tested so far:
pH- over 8.2
CYA- ~110
(Leslies Pools got CYA 110 and pH 8.0, plus got TA-130, CH-400, plus TDS and Phosphates readings- oh and 0 FC of course)
(BTW- the guy at Leslie's thought I was an idiot for wanting to use liquid chlorine to shock the pool. When I politely insisted I didn't want to use their methods or products, I suddenly stopped getting helped even though there was only one other customer in the store. I went to Lowe's to buy a brush, leaf skimmer and hose nozzle, instead- all for about 1/2 of what it would have cost at Leslie's. Oh, and Lowe's has 2 gallons of liquid chlorine for about $7.)
So I'm thinking I need to first lower CYA. Is this done by replacing water? What's the best way to drain water? If I want to get CYA down to about 50, does that mean I should drain half the water out, then replace? Any chance of having water table issues?
Once I get the CYA down, I'm thinking it's time to lower the pH. Then it's time to shock. Does that sound right to you?
Thanks!
