Hi All,
As always, thanks for providing such a helpful forum.
I'm looking to install a Intellichlor SWG. My pool guy wants to charge me an insane fortune to do it so I'm looking into doing it myself. In general, it looks pretty straight forward except that Pentair's documentation is horrible and inconsistent. I have some general questions, questions on wiring, and a pretty basic plumbing question I was hoping to get some help with.
Equipment: Pentair Intelliflow, Pentair Mastertemp 400, Pentair Easy Touch
General Questions
1. I have a 30-35,000 gallon pool. Thoughts on whether it's worth upgrading to an IC60? It's a $250 difference.
2. I've heard others here talk about hooking the SWG up to an independent timer. I have an Easy Touch system. I'm assuming an independent timer isn't necessary with automation, but want to confirm.
Wiring Questions
3. Is the AC wiring from the Power Center supposed to tie into the load or line side of the pump relay in the Easy Touch load/power center? I've seen others here mention the load side, but the diagram in the installation manually clearly says line. See attachments.
4. The wiring diagram shows 4 wires coming out the Intellichlor Power Center screw terminal to Easy Touch control panel but only 2 wires going into the J20 comm port on the Easy Touch circuit board. See attachment. I assume only the 2 data wires are necessary. Is that right? And does anyone know if that wiring comes with the Power Center or do I need to buy it separately?
Plumbing Question
5. I'm going to need to rerun some of my plumbing to accommodate the SWG. I have a Pentair Mastertemp heater. It looks like there is a there is a union coupler that looks like this (Pentair Union Kit, 2 Inch Union Half x 2 Inch Slip Connection | PKG 188 PKG 188Z) that screws onto the heater inlet/outlet at one end and then the pipe is glued to the other. If I rerun the line coming out of the heater, I'll need to replace that union coupler. Can anyone confirm that I'm looking at the right part?
Thanks in advance!
General Questions
Wiring Questions
Plumbing Question
Thanks in advance!
