I have been reading the forums about maybe switching to an SWG after all these years, and going with the old BBB routine.
Below is my purchase history from Leslie's Liquid Chlorine 4-Pack of 1 Gallon Bottles, 10%-12.5% Available Chlorine Strength. The prices below are impacted by Leslie's reward dollars being applied to purchases. We usually open the pool around April/May, depending on the water temperature, which accounts for the heavy Chlorine use around these months.
Below is an example of just the parts, which I am not sure are everything I would need if I go the DIY route. I have more research to do to determine if there are any additional parts required. I still need to learn more about the salt needed and at what volume. The ROI seems promising. Most likely will stick with Pentair due to all of my equipment is Pentair.
Total Cost | Cases | Gallons | ||||
5/8/2024 | $227.26 | 6 | | 24 | ||
6/8/2024 | $253.21 | 8 | | 32 | ||
7/22/2024 | $133.10 | 4 | | 16 | ||
8/12/2024 | $213.19 | 6 | | 24 | ||
9/15/2024 | $211.02 | 6 | | 24 | ||
10/26/2024 | $147.18 | 4 | | 16 | ||
11/25/2024 | $125.84 | 4 | | 16 | ||
2/14/2025 | $187.65 | 6 | | 24 | ||
4/17/2025 | $202.26 | 6 | | 24 | ||
4/24/2025 | $195.87 | 6 | | 24 | ||
$1,896.58 | 56 | 224 | $0.12 |
