I am having a tough time maintaining a consistent FC level with my SWG. At issue is that I have an autocover that may remain closed for days at a time (I have little kids, so don’t want to leave it open when not in use), but then some times it will be open all day for a couple of days. Every time I leave it open, I end up having to turn my SWG up to keep the FC levels above 2, but then if I don’t turn it way down, after a couple of days with the cover closed my FCs climb up to 10+, so that I have to leave it open just to let the sun burn off some of it.
Is this normal to have to be constantly tweaking the SWG level? It wouldn’t be such an issue if I were home, but my wife doesn’t want to be messing with this while I am at work, depending on whether the kids are going to use the pool or not, so I am always guessing (often wrong) whether to run it high or low for the day.
Is this the reason the recommended CYA level is so high? My pool installer told me not to bother with stabilizer at all, and I asked on here and someone said I would be fine at 50, but I’m wondering if that’s my problem.
My tests this morning:
FC: 10
CC: 0
CYA: 45
TA: 70
PH: 7.4
Salt: 3200
CH: 400
FC: 10
CC: 0
CYA: 45
TA: 70
PH: 7.4
Salt: 3200
CH: 400
