- Apr 3, 2025
- 54
- Plaster
- Hayward Aqua Rite (T-15)
Thanks Jim. All excellent points. I cited 1.8x simply as the outcome from an appropriate (and very low) pump speed, not as the end state itself. I was pleasantly surprised that I was getting a fairly high flow rate at what I consider to be a low rpm w/ correspondingly low power draw. Very cool. Was surprised when pool tech had pump running at 85% for half the day, then at 75% the other half. Seems excessively high, especially since there was little to no plaster dust after they acid washed before fill...
Sounds like 'low and slow' is the way to go... and the dialing up toward full speed for selective cases, like vacuuming through skimmer line, etc.
