- May 23, 2015
- 25,707
- Plaster
- Pentair Intellichlor IC-60
I do not think this is correct. As you lose chlorine through outgassing from the pool, you will end up with a relative increase in NAOH as a byproduct of the electrolysis reaction. This gradually raised the pH in SWG pools.
The cost of lowering pH on a regular basis should be factored in here and can be substantial in some cases. I have to add quite a bit of MA regularly.
Unless the SWG is installed incorrectly, chlorine gas loss never happens. The chlorine gas produced by the SWG has a very high solubility in pool water and completely dissolves and hydrolyzes before ever leaving the return lines. The bubbles that come out are hydrogen gas bubbles because hydrogen gas has very low solubility in water. When chlorine reacts with anything in the water, it gets reduced back to chloride ion. Those reactions all produce a proton (H+) and are acidic. Therefore the total hydrogen ion change is zero.
SWGs are pH neutral.
