It looks like about a 9 month payback on installing a two speed motor in place of my existing 2 HP motor at $0.10 or so a kwh. My concern is whether this is likely to cause flow switch problems with my Hayward Aquarite. I've got 2" plumbing and the pad is about 15' from the pool. Motor is likely oversized for normal pool operation, but nice when you turn the waterfall on. $500 wasted if I have to keep it on high to use the SWG. Seems likely to work as I read of lower HP two speed conversions and the flow switch for Hayward looks to be the same regardless of salt cell size.
Anyone know with reasonable certainty whether the two speed A.O. Smith B2984 at low speed will push enough flow to keep the flow switch active? Any recommended impeller changes?
Thanks in advance!
Thanks in advance!
