I have an 18,000 gallon inground fiberglass pool with an AutoPilot SWG. I just want to check to see if other members with a SWG and solar cover follow the same procedure.
I run my single speed pump 10 hours a day. While the cover is on I have the salt cell set to 50%. At that setting the chlorine levels seem to maintain 6ppm. Once I pull the cover off and we start swimming in the pool I notice the chlorine gets depleted pretty quickly. I'm still learning the system but it seems like I have to turn the salt cell up to 75% while the cover is off and the pool is being used. The cover usually comes off friday night. At 75% with the cover off the SWG seems to maintain 3ppm chlorine levels. Sunday night I put the cover back on and I leave the salt cell at 75% until the levels reach 6ppm. I have also read that SWG typically result in a pH that slowly rises. My pH actually decreases as time goes on, the decrease is around 0.2 per week.
This is my first year but I haven't noticed any algae growth yet. Is there anything I should change?
