I did a SLAM last week because water was cloudy and there was some visible algae on the shady side of the bottom and on the ladder steps which are also shaded. I SLAMmed it for a few days with no improvement so I bumped it up to Mustard Algae SLAM level. The water instantly cleared, the filter cartridge was clean, I passed the overnight test and I thought I was home free so I let the FC drift down.
Today the water looked a tiny bit cloudy again so I checked the filter cartridge and sure enough, it was full of bright green algae. Does bright green algae indicate mustard algae? Might be worth noting that at no time during either SLAM did I have significant chlorine loss. I was basically topping it off a few times per day to bring it back up to SLAM/MA level. I had .5 or less CC the whole time and never lost more than 1ppm per night. Most nights I lost zero.
I have brushed daily, removed the solar cover, and checked everywhere for hidden algae. There aren't many places for it to hide, although if the consensus is that it's not mustard algae, I will remove the ladder and see if there is any hiding inside. This is a last resort because I have the outside steps of the ladder dug into the ground a few inches and am dreading taking it out. I will if I have to though.
FC - 12 (Have since brought it back up to MA level of 24)
CC - .5
PH - 7.2 (Been keeping it low because I did the Metal Stain Removal thing a few weeks ago.)
TA - 100
CYA - 40
Thanks!
*Edited to add another potential clue. This situation has happened to me two times before and in all three instances the algae started after returning from being away for a few days. While I was away the FC never got down below minimum level. In fact, it was well above.
CC - .5
TA - 100
CYA - 40
Thanks!
