I am hoping to start up the SWCG this weekend as I will finally have the electrical ready. Before adding salt to the pool yesterday I tested the water for salt using the Taylor K-1766 kit. Very simple test (10mL of water, one drop of R-0630, add one drop at a time R-0718 until milky brick red). Took 7 drops, so the result was 1400ppm. I haven't added any salt to the pool prior to this test. The pool water came from the community water source that supplies our house. I checked the expiration date on the test kit chemicals and both say they're good until 2020. I've had the pool up for a little over a month now. 30' above ground. The only chemicals I have added to the pool are 10% bleach, muriatic acid, and CYA. Does this level of salt sound normal?
