Hello, I have Hayward Phoenix pool cleaner which does a good job of getting rid of all the debris which has sunk to the bottom of the pool. I run the 2.6HP Pentair pump at 2200RPM for 8 hours everyday for my 13000 gallon pool. I do not get too much of the large debris except when the gardener cleans up once a week, which I rake up as soon as he is done. Rest of the time it's just few leaves if that. The pool water is clean to look at but there is fair amount of tiny surface debris (insects, very fine plant threads etc) floating at the top. I would really like to find a solution to this problem without adding any more equipment. I don't have a weir door on my skimmer.
Should I remove the pool cleaner from the skimmer one day a week so that the surface water is sucked in instead of water from the bottom of the pool? I'll appreciate any help regarding this.
