- Mar 7, 2021
- 21
- Plaster
- Pentair Intellichlor IC-40
New Pool Owner here needs a little hand! Thanks to the amazing TF-Pro Test Kit and the Pool Math app (paid subscription) I am getting better but I need some help figuring out what I need to improve and how to tweak/optimize my water and chemical additions.
Pool Math Log Share = PoolMath Logs
If you check my link above you will find that I have optimized a few of my levels in my pool. The pool is brand new construction and has only had water in it for exactly 1 week so I recognize results may still jump around. My pool is in direct sun (no trees in backyard) from sun up through about the 3PM hour, so it gets lots and lots of sun. I am using 10% Bleach from HomeDepot and getting my reading at about .5 by the next evening after adding the suggested amount which has been about 40oz - 70oz daily. I just got CYA to 50 so I may get better chlorine longevity going forward.
I am also having my pH continually climb daily even after using muriatic acid at the indicated dosage to lower it.
Questions:
- Should I expect all chlorine to dissipate daily?
- Why does my pH continue to climb up even after adding the recommended dosage of muriatic acid?
- Should I add some tri-chlor pucks to my chlorinator to supplement the liquid bleach?
- What else do you suggest based on reviewing my pool log shared above/
Questions:
