- Sep 30, 2019
- 21
- Plaster
- Pentair Intellichlor IC-40
Hi,
I had a single speed pump controlled by an Intermatic P1353ME 3-circuit with a fireman's wire to the Raypak. The Intermatic has a timed cooldown function that's (was) reasonably fool proof. How can I do this with a recently upgraded Superflow VS? There's not much documentation out there on this topic. I think I can manually time the Intermatic against the RPM/time programming on the VS but I don't think I should trust that. Can it signal from the COM port on the VS or would reliance on the heaters pressure switch be a decent enough redundancy? Is there a smart or proper way to do this?
Patrick
Patrick
