just took over my own pool duties. Pool has for years been taken care by a pool company that used pucks & shock. Tested everything tonight w/ the TF100 Kit.
Its obvious I have a algae problem along with tons of pollen falling in the pool down here in Houston currently.
My test # are FC: 6; TC: 7.5; CH: 400; TA: 90; PH: 7.5ish; CYA: 100. From my research I need to drain & refill, my question is how much water do I need to drain?
My pool is approx 25K gallons & water is expensive.... Pool definitely currently has a green tint to it & is very cloudy.
Any help / suggestions is appreciated.
