With a pending home addition in the works, we are going to get a "less permanent" above ground pool. We like the Summer Waves Elite 18'x52" round pool. However, I know the pump/filter is likely terrible and we want a salt system.
I'm thinking to simply add the Intex Salt and Sand system with a 2150 gph rating. Would this be adequate for the pool? From my calculations quickly, it looks like the pool is under 9000 gallons which works out to less than 20 gpm (1200 gph). I'd remove the pump from the included canister and just use an adapter on the pump body.
Also, do the legs need a pad under them or is installation directly on grass (ground cover/mat) ok?
Does this sound ok (pump setup)? It would be a 1-3 year pool and after house addition is done, we want to do a permanent above ground aluminum/resin pool.
Thanks!!
Here is the pool:
https://www.homedepot.ca/en/home/p.dark-wicker-18-feet-round-metal-frame-pool-package---52-inch-deep.1001068467.html
Here is the pump:
https://www.amazon.com/gp/aw/d/B00PHX0D9I/ref=mp_s_a_1_3?ie=UTF8&qid=1527096022&sr=8-3&pi=AC_SX236_SY340_FMwebp_QL65&keywords=intex%2Bsaltwater%2Bsystem&dpPl=1&dpID=41d2yR38NiL&ref=plSrch&th=1&psc=1
Thanks!!
Here is the pool:
Here is the pump:
