Hi all,
We recently opened our pool for the summer for the first time (we purchased a home with a pool over the summer) and after several rounds of a local pool company shocking it to kill the algae and battling cloudiness, we discovered our CYA levels were around 100. We drained the pool halfway TWICE, testing after the first time (CYA levels around 60) but we haven't tested since the second time (ditched the $$$ pool guy to learn to do this ourselves). I'm assuming CYA is around 30 currently, but I'll be testing later to make sure. Cloudiness has mostly cleared up except for in the deep end where it's still persistent.
Current Levels:
Chlorine: 2.0
BR: 4.4
PH: 7.6
Alk: 170ppm
What do you suggest for clearing up the last remaining bits of cloudiness in the deep end? Also, I noticed our pool company had put chlorine tabs in a floater in our pool. After browsing the threads a bit I'm getting the impression this may not be a good idea?
Thanks for all advice!
Current Levels:
Chlorine: 2.0
BR: 4.4
PH: 7.6
Alk: 170ppm
