- Apr 21, 2020
- 1,559
- Fiberglass
- Pentair iChlor 30
So wire the SWG thru a timer and control the SWG runtime instead and let the pump run 24/7.
No need to micromanage the SWG - Based on your CYA, determine the FC target range. Keep FC within that range - maybe even a few points higher. Never let FC get to minimum.
Testing once every two weeks or so isn't often enough. The FAS-DPD and pH tests takes less than 5 minutes. Once or twice a week should suffice - once the SWG is dialed in.
I test as often as needed. When I get the same FC reading week after week, I don't have any problem going two weeks between tests.
