Good morning all,
I believe I have a small to medium sized suction-side leak that is drawing air into the pump and filter (Jacuzzi cartridge style). It has already destroyed 1 older style pump that did not have an auto-shutoff feature, when it ran dry overnight and burned out. I have leak tested all of the above-ground plumbing (bubbles and also radiator dye) and there is no evidence of leak.
If I left the purge/vent at the top of the filter open to continuously leak a small amount of air, would this be a reasonable temporary solution until I can locate and repair the suction-side leak? Or is this insane?
Thank you in advance for any guidance you can provide.
