Ok, got a big air leak somewhere.
New, lubed o-ring on old pump basket cover. Don't see any cracks.
Tried running water over all the above ground connections, no change.
Tried wrapping connections tightly in plastic grocery bags, no Saran Wrap in the house. No change.
Turned off feed from skimmer, no change.
Opened skimmer feed, turned off feed from mains water in basket went WAY down.
That tells me air leak thru skimmer feed, as skimmer itself is full, weir door working as should, with lots of rain this year keeping water level up.
Problem seems to be under the concrete. Now what?
