Subtract 1/3 CYA value from TA reading?
datadr93
201
Eastern Ohio
Fiberglass
Pentair iChlor 15
Never did this once
From Taylors website:
False-high reading due to cyanuric acid
Cyanuric acid (CYA) titrates as total alkalinity when CYA is greater than 30 ppm. Adjust for this by subtracting 1/3 of your CYA reading from your total alkalinity reading to get the correct alkalinity value. For a more detailed explanation, refer to page 14 in your 2004B booklet.
Since you are using pool math, don't worry about any adjustments, pool math does that when it calculates CSI. Enter TA as the actual value from your test kit.
Reactions: datadr93
