Hello!! I have a 30ft. above ground pool in North Mississippi. We had about 5 straight days of rain and torrential down pours. There is a 30ft Cedar Tree about 20 feet from my pool so I'm guessing this is my problem.
I balanced my water using Pool Math Calculator...shocked accordingly with 10% Liquid Chlorine with no results at all..kept getting darker green... (having yard party this weekend) went to WalMart and Purchased a 4 in 1 Shock..again only results is darker green..Initially I could see the bottom clearly. Got desperate and went to Family Leisure with my problem..they were out of TKO which she said would be very good but the combination of Ultima Total Control Shock & Algaecide (6 lbs) would work in combination with Ultima PhosFIGHT Remedy (1 qt.) Put all that in around 6:30 PM last evening,,,,Pool still as dark green. Test Results at this time:
FC/CC=11ppm, CYA - 30, TA=110, pH=8.20 (recommends adding 2c. 1 oz Muratic acid (at this point I thought not to add anything until I got advice from this forum)
Your advice will be greatly appreciated..Should have come here first.
Best Regards,
Vivian
Best Regards,
Vivian
